API to export to AD
Discussion in 'CRM / Helpdesk / App Integration' started by npereira, Jan 19, 2018.
  1. npereira
    Jan 5, 2009
    22
    hi all,
    Not sure if this is even possible. I’m looking at the ability to export the list of 3cx extension, and match it against active directory as soon as an extension is created in 3cx. If the user doesn’t exist inAD, create it or send an email to have the ID created with the information gathered from 3cx extension profile.
    Is there an API that does this or documentation on the API framework (I’m not a programmer) but would list what is available as API?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,064
    75
    Hello @npereira,
    The is no API to do this automatically. You would need to use the 3CX Call Control API to read the extensions from 3CX, get the information you need, and create them in Active Directory.
    Kind regards.
    Ernesto.
