APP CRASHES WHEN DIALLING OUT
Discussion in 'iOS' started by black6, Feb 22, 2013.
  1. black6
    Nov 26, 2012
    9
    Hi All,
    We have just installed the 3CX V3 app on our iPhone 4 running IOS V6.01 which looks promising.
    When we try to dial out the app crashes and returns to desktop, anyone else having this problem? We have tried a couple of reinstalls but no luck.
    Regards,
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Did you give permission to the application to access your Contacts? Please do this and let me know if it works for you
    go to Settings > Privacy > Contacts > and set the switch to ON for 3CXPhone 3. This most likely happens because during installation you denied access from 3CXPhone to your Contacts
  3. black6
    Nov 26, 2012
    9
    Yes, that fixed the problem. It seems that if you do not allow it to use contacts during install then the app does not work.
    Thanks for help with this one, we will continue testing now.
    Regards,
  4. AndreasP_3CX
    3CX Support
    Feb 15, 2013
    196
    You are welcome, i am glad your problem was solved
    Regards
