App crashes when not on local lan
Discussion in 'iOS' started by 7designs, Jul 26, 2011.
  1. 7designs
    Jul 19, 2011
    I have the app set to use external server and works on local LAN WiFi but when at work the app crashes when launching.
    Port 5060 is open.
  2. willow
    willow Member
    Mar 1, 2011
    471
    what release?
  3. 7designs
    Jul 19, 2011
    Version is 1.0.23
  4. 7designs
    Jul 19, 2011
    Now it crashes all the time. Have to uninstall and reinstall to get it to work again.
  5. StefanW
    Jun 2, 2009
    1,230
    95
    is the screen just blank for a very long time?
    This will be fixed in the next version. it is related to STUN resolving.
