App. wil not start after installing on VISTA
Discussion in 'Windows' started by orenr, Jan 25, 2008.
  1. orenr
    Jan 25, 2008
    Hi all,
    after installing the app on my Vista machine (Xeon+4gbRAM), a small phone icon apeares oon the system tray. the app wont respone/open on any kind of click. trying to start the app again, i get a message it is already open. can not close and/or even kill the process.
    any ideas what is my problem?
    thanks,
    Oren R.
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    x64 or x86 version of vista?
  3. orenr
    Jan 25, 2008
    Intel Xeon DuoCore x86
  4. matthijsolislagers
    140
    It works fine on my Vista business x86. So it is not a common vista problem. I did read someting about problems with vista x64 but that is not your problem.
    Did you try to reinstall the program?
  5. orenr
    Jan 25, 2008
    Yes. several times. i know it is something in my system because i get the problem with any soft phone. didn't figure out what is the reason.
