Append customer input to text file
Discussion in 'Call Flow Designer' started by Walt Longmire, Dec 7, 2017.
  1. Walt Longmire
    Dec 7, 2017
    Trying to have CFD create/append a text file for when the auto-dialer makes a call and the recepient presses "1" if they choose, enters data, and presses # to write the data to a text file and terminate the call.
    I've tried UserInput > Valid Input > ReadWriteFile >
    File Component:
    "C:\\Text\\textfiletowrite.txt"
    Append
    Write > Content to Write > UserInput1 > Result
    But the only thing ever written to the file is "ValidDigits"
    So I tried Write > Content to Write > UserInputResult > ValidDigits
    Once again the only thing written is "ValidDigits"
    Next I tried creating a variable "TextFile" with the Exression > UserInputResult.ValidDigits > The user enters data UserInput2 > upon valid input > ReadWriteFile
    File Component:
    Append
    Write > Content to Write > the variable "project$.TextFile"
    Once again all that is written is "ValidDigits"
    Not quite sure what I'm missing.
    Also, what I know about SQL Query and C# wouldn't fill a thimble.
    Thanks.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    897
    69
    You need to use the Buffer property of your UserInput component. For example:
    userInput1.Buffer
    Kind regards
  3. Walt Longmire
    Dec 7, 2017
    Hey that worked!
    I moved the Variable from UserInput1 to UserInput2 > Valid Input, changed the Expression to UserINput2.Buffer and now my text file populates with the correct data.
    Thanks Ernesto :)
