Append text to inbound caller name
Discussion in 'Call Flow Designer' started by Alex8000, Jan 10, 2018.
  1. Alex8000
    May 4, 2017
    Hello all,
    I have been looking for a way to append (or prepend) text to the caller name with a value as retrieved from a database query.
    Would you be able to confirm that this is indeed possible, and what the CallerID 3CX variable would be?
    Scenario:
    - Inbound caller gets connected to CFD
    - CFD queries MS SQL database with Caller ID ('123')
    - CFD stores query result value ('abc) in variable strName
    - CFD prepends variable value to CallerName (CallerName becomes 'abc %regular CallerName%')
    Many thanks!
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,611
    126
    Hi @Alex8000,
    Unfortunately it's not currently possible to do it. The caller name can't be changed from the CFD app. We'll be providing a solution for this in a future version, as this is a very required feature, but we don't know when this is going to be...
    Kind regards.
    Ernesto.
    Alex8000 likes this.
  3. Alex8000
    May 4, 2017
    Hi Ernesto,
    Many thanks for your answer.
    This is unfortunate, but good to hear that this is being worked on!
    Just to be sure that my 'broader plan' is not endangered by this, could you verify that the below does look like a valid application for CFD?
    - CFD looks up CallerID in MSSQL CLID <> Queue table
    - CFD connects caller to specific queue based on query result
    Thanks a lot,
    Alex
  4. edossantos
    Jun 27, 2007
    1,611
    126
    Hi Alex,
    Yes, you can do all that with a CFD app.
    Kind regards.
    Ernesto.
  5. Alex8000
    May 4, 2017
    Hi Ernesto,
    That's terrific, thanks!
