Apple Watch
Discussion in '3CX Phone System - General' started by Eric Nush, May 17, 2017.
  1. Eric Nush
    Feb 13, 2017
    6
    Has anyone been able to get notifications to go to their Apple Watch? I have all the settings correct where it will push notifications to my iPhone, and will even push to the lock screen. But it doesn't send notifications to my watch.
    I checked the watch settings and could think of everything possible. Just curious to see if anyone else has it working, or if this is some strange bug. Thanks!
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,528
    71
    Hi Eric
    Just for your information:
    we don't have any AppleWatch-specific handling whatsoever in the iOS client, so whatever interaction/communication between it and and the AppleWatch is Apple "native" only.
    Regards
    vali
  3. alinajetly
    Jun 13, 2017
    There was a problem with notification in my apple watch too, but I find some solution here. Check Your watch and iPhone closer to each other?, and your iPhone and apple watch connected or not. and complete guide with step by step read this thread
    ginaadrson likes this.
