Application Error in Event Log
Discussion in '3CX Phone System - General' started by coreybrett, Apr 13, 2010.
  1. coreybrett
    Apr 12, 2010
    72
    I’m getting the following errors in my event log.
    Code:
    Event Type:	Warning
    Event Source:	EventSystem
    Event Category:	(52)
    Event ID:	4356
    Date:		4/13/2010
    Time:		11:13:11 AM
    User:		N/A
    Computer:	BELFAST
    Description:
    The COM+ Event System failed to create an instance of the subscriber {6CF90891-3E04-4092-B96C-28E071EEEACB}.  StandardCreateInstance returned HRESULT 8000401A.
    Event Type:	Error
    Event Source:	Application Error
    Event Category:	None
    Event ID:	1001
    Date:		4/13/2010
    Time:		11:13:41 AM
    User:		N/A
    Computer:	BELFAST
    Description:
    Fault bucket 05100699.
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Data:
    0000: 42 75 63 6b 65 74 3a 20   Bucket:
    0008: 30 35 31 30 30 36 39 39   05100699
    0010: 0d 0a                     ..
    Event Type:	Error
    Event ID:	1001
    Date:		4/13/2010
    Time:		11:13:49 AM
    User:		N/A
    Computer:	BELFAST
    Description:
    Data:
    0010: 0d 0a                     ..
    Event Type:	Information
    Event Category:	(100)
    Event ID:	1004
    Date:		4/13/2010
    Time:		11:13:42 AM
    User:		N/A
    Computer:	BELFAST
    Description:
    Reporting queued error: faulting application w3wp.exe, version 6.0.3790.3959, faulting module kernel32.dll, version 5.2.3790.4480, fault address 0x000000000000dd50.
    Data:
    0000: 41 70 70 6c 69 63 61 74   Applicat
    0008: 69 6f 6e 20 46 61 69 6c   ion Fail
    0010: 75 72 65 20 20 77 33 77   ure  w3w
    0018: 70 2e 65 78 65 20 36 2e   p.exe 6.
    0020: 30 2e 33 37 39 30 2e 33   0.3790.3
    0028: 39 35 39 20 69 6e 20 6b   959 in k
    0030: 65 72 6e 65 6c 33 32 2e   ernel32.
    0038: 64 6c 6c 20 35 2e 32 2e   dll 5.2.
    0040: 33 37 39 30 2e 34 34 38   3790.448
    0048: 30 20 61 74 20 6f 66 66   0 at off
    0050: 73 65 74 20 30 30 30 30   set 0000
    0058: 30 30 30 30 30 30 30 30   00000000
    0060: 64 64 35 30               dd50
    Event ID:	1004
    Date:		4/13/2010
    Time:		11:13:50 AM
    User:		N/A
    Computer:	BELFAST
    Description:
    Data:
    Has anyone else seen these?
    This is a WinSrv2003 x64 box, with only 3CX installed.
  2. kevswannuk
    Apr 16, 2010
    You might have already figured this out but the problem is not to do with 3CX, but rather the .Net installation on your server.
    The IIS pool is crashing with the error:
    This is a known problem with .Net and IIS.
    Not certain what version of .Net you are running but you could try uninstalling / reinstalling or upgrading to 3.5.
    Hope this helps.
  3. johnmichael
    Apr 6, 2010
    48
    You can also try to check the webpage that you are running on IIS.
    It has something to do with the worker process.
  4. coreybrett
    Apr 12, 2010
    72
    This is a fresh install of 2003R2, that was completely updated. The only app installed on it is 3CX.
    Thanks for the tip. I'll try reinstalling .NET.
  5. coreybrett
    Apr 12, 2010
    72
    Well I had 8.0.10116.583 of 3CX, but I upgraded to 8.0.10824.716.
    That seems to have fixed all of the issues I was having.
    Event Logs are nice and clean now. Also, it seems to have fixed the fax server.
