Solved Appstore
Discussion in 'iOS' started by natejasper, Apr 14, 2018.
  1. natejasper
    Apr 14, 2018
    Hi all, Please help me,
    My Ip6s+ lose appstore, I don't know why, but I can not find it at anywhere?
    How can I find it?
    Thanks for your help,
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,468
    66
    @natejasper
    Not an issue to hear every day :D
    The only "normal reason" for such disappearance I'm aware of is device's Restrictions - maybe you "played" there.
    So, please check Settings/General/Restrictions. If Restrictions are enabled, then check there if you restricted the Installing Apps - if is unchecked, it means you hide it. Check it and see if App Store appears back.
    Hope it helps
    vali
    Later edit:
    Better explained in this article
    https://www.igeeksblog.com/app-store-missing-on-iphone-ipad/
    #2 Vali_3CX, Apr 14, 2018
    jed likes this.
