are access numbers supported?
Discussion in '3CX Phone System - General' started by fred.flint, Oct 18, 2014.
  1. fred.flint
    Oct 16, 2014
    Some provider are 9x cheaper for dialing mobiles for example, is it possible to make 3cx use these when a outgoing mobile is detected and retain the caller id ?
    Here is an example provider
    http://www.cheapcalls.co.uk/program-your-phone/avaya-ip-office-phone-system
    11,077
    324
    As long as the mobile numbers in your country are identifiable by prefix (I know they usually are in the UK), then you can route those calls out over a different provider, using outbound rules. As far as the caller ID displayed... that depends on the provider you use. Some allow you to spoof (change) the caller ID to whatever you want, and some will only send the number(s) that they assigned to you. In some countries this is also a requirement
    It's not necessary to provide examples, as most members are well aware of less cost providers.Keep in mind that , in many cases, you get what you pay for, so do your homework.
