Are agents logged in to queue...
Discussion in 'Call Flow Designer' started by imseanbrown, Sep 8, 2017.
  1. imseanbrown
    Apr 17, 2017
    7
    I come from the asterisk world... We need to replicate the following:
    On incoming call.... If there are agents logged in to a specific queue (doesn't matter if they're on the phone or not -- just need to know if agents logged in), we need it go to one IVR... If there are NO agents logged in (all agents logged out) it should go to a different IVR....
    Whats the easiest way to accomplish this?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,597
    125
