Are the 2 line buttons on Yealinks needed for anything?
Discussion in '3CX Phone System - General' started by neville, Jul 27, 2017.
  1. neville
    neville New Member
    Apr 23, 2012
    226
    42
    If you are only going to use the first account on the yealinks, is there any reason to have the lines buttons configured. It seems like a waste of space to me. I have tested and have not seen any loss of functionality when I changed them to Shared Park Buttons. This will involve a custom template which I am ok with.
    Thoughts?
    11,105
    329
    They are there to use as you see fit. others choose to use them for addition lines. If you don't need the line keys, in many cases, less expensive sets are available as an option. For most, the small added expense allows for future flexibility.
  3. neville
    neville New Member
    Apr 23, 2012
    226
    42
    I was talking about the two reserved line buttons.
    Sorry for the confusion.
    Chuck
  4. Brian Cross
    Brian Cross New Member
    Jul 26, 2017
    109
    29
    I always removed them and configured BLF buttons.
  5. jbryant84
    jbryant84 New Member
    Apr 6, 2016
    109
    40
    You can have a call on hold, and use the second line key to make another call. That's the only use I've found, and there's probably another way to do that.
  6. Brian Cross
    Jul 26, 2017
    109
    29
    This is correct but the phone also prompts you as well, so I always removed these buttons. I usually only deployed T46g & t48g phones.
