Are there any working Tunnel Configurations?
Discussion in 'Windows' started by mandev, Mar 4, 2008.
  1. mandev
    Feb 27, 2008
    35
    Are their any working Client Tunnel configurations at all?
    If so please post your .ini files, log files and other configuration data.
    I've tried just about everything but no luck and it was a key reason to trial 3CX.
    Les
  2. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    Hi All
    Have a look at the attached and revert should you still encounter issues.
  3. mandev
    Feb 27, 2008
    35
    Thanks but this is a simple restatement of the original instructions.
    And I DONT have any tunnel port options in the latest server, had to check the .ini files.
    Note there are others with the same problems.
    Are we to conclude there are NO Clienet/Tunnel working configurations? If there were surely somebody would have a tunnel log to proove it?
  4. William400
    Aug 21, 2006
    1,005
    Hi Mandev
    Can you please clarify what INI file you are expecting.
    If you are using a Client to server tunnel then you only open a port on the firewall. There is no need to touch any INI file manually.
    If you are using a server to server tunnel then you need to setup the Tunnel in Slave mode, again with no need to touch any INI file.
    The Tunnel options on the server are found in the 'Add Bridge' section of the UI.
    If you can clarify the issue and requirment we can assist you.
