ASK HELP
Discussion in '3CX Phone System - General' started by konedou, Sep 12, 2008.
  1. konedou
    Sep 11, 2008
    in English
    Thank you for your answer…
    will be it possible qu I can of outside (of my mobile) to send a call towards the PBX (3CX), by an analogical getaway…. that is possible…. but will be t' it possible that I can join an extension (100 or other) by composing the number of l' extension then to emit calls via this extension towards the whole world ???.
    en français
    salut à tous
    Merci de votre reponse... sera t'il possible qu je puisse de l'exterieur (de mon mobile) envoyer un appel vers le PBX (3CX),
    par une getaway analogique .... cela est possible .... mais sera t'il possible que je puisse joindre une extension (100 ou autre ) en composant le numero de l'extension puis emettre des appels via cet extension vers le monde entier.
    merci de votre aide.
    thank you for your assistance.
    konedou
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    I think in this steps
    set your line 1 to ring in ext 100
    make a dial rule 92 to dial using line 2
    forward ext 100 to 92
    I think you'll get dial tone
    dial any number
