Ask How to set 3cx my office and I need Gateway or not ?
Discussion in '3CX Phone System - General' started by demoinvest, Dec 27, 2013.
  1. demoinvest
    Dec 27, 2013
    Hi, I am new using IP Phone
    Can anybody help me to understand how to setup 3CX Phone System for Windows for my office ?
    please see at image at attchment
    my office need to using 16 extension phone internal
    how can possible to using 3CX Phone System for Windows ?
    10,368
    228
    If you connect to a VoIP provider for all of your calls then you do not require a gateway. A gateway is only used to convert from SIP VoIP (within 3CX) to PSTN lines, ISDN, or GSM.
    It also helps if your VoIP provider supports 3CX but most will work using generic settings. You might want to ask them if they are aware of any other of their customers currently using 3CX .
