ASP.NET error....
Discussion in '3CX Phone System - General' started by lamsoft, Jan 24, 2009.
  1. lamsoft
    Jan 23, 2009
    12
    Last time I cannot start the web server, thus I install the IIS on my WinXP.. but... in event log has this couple of errors....
    Code:
    Event Type:	Warning
    Event Source:	ASP.NET 2.0.50727.0
    Event Category:	Web Event
    Event ID:	1309
    Date:		2009-01-24
    Time:		08:47:41 PM
    User:		N/A
    Computer:	LAMSOFT-SERVER
    Description:
    Event code: 3005
    Event message: An unhandled exception has occurred.
    Event time: 2009-01-24 8:47:40 PM
    Event time (UTC): 2009-01-24 12:47:40 PM
    Event ID: 199caf5990104e11bbeb77d3fe734425
    Event sequence: 1163
    Event occurrence: 1
    Event detail code: 0
    Application information:
        Application domain: /LM/W3SVC/1/ROOT/management-1-128772729751875000
        Trust level: Full
        Application Virtual Path: /management
        Application Path: C:\Program Files (x86)\3CX PhoneSystem\Data\Http\Interface\
        Machine name: LAMSOFT-SERVER
    Process information:
        Process ID: 6304
        Process name: w3wp.exe
        Account name: NT AUTHORITY\SYSTEM
    Exception information:
        Exception type: ArgumentNullException
        Exception message: Value cannot be null.
    Parameter name: collection
    Request information:
        Request URL: http://192.168.0.1:81/management/Route/1.76.1/moz/en-US/Default/Content.MainForm.wgx?vwginstance=
        Request path: /management/Route/1.76.1/moz/en-US/Default/Content.MainForm.wgx
        User host address: 192.168.0.5
        User: lamsoft
        Is authenticated: True
        Authentication Type: Forms
        Thread account name: NT AUTHORITY\SYSTEM
    Thread information:
        Thread ID: 8
        Is impersonating: False
        Stack trace:    at Gizmox.WebGUI.Server.Content.ProcessRequest(HttpContext objHttpContext)
    Custom event details:
    For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
    Code:
    Event Type:	Warning
    Event ID:	1309
    Date:		2009-01-24
    Time:		08:52:13 PM
    User:		N/A
    Description:
    Event code: 3005
    Event time: 2009-01-24 8:52:12 PM
    Event time (UTC): 2009-01-24 12:52:12 PM
    Event ID: 155353226b9942f5b1d809282ed43e27
    Event sequence: 1289
    Event occurrence: 2
        Trust level: Full
        Process ID: 6304
        User: lamsoft
    Thread information:
        Thread ID: 1
  2. lamsoft
    Jan 23, 2009
    12
    In addition, i'm using windows xp with IIS, Microsoft limited only 1 web site is allowed to create, and I found that the web site "ivr" cannot be started (because it is another web site)
    if i call any extension such as 9999 or digital receptionist, the system returned that "An error occurred in IVR session, sorry"
    and i find that there is an error log under "C:\Program Files (x86)\3CX PhoneSystem\Data\Logs\Backup\20090125\"
    Code:
    2009/01/24 >>
    21:39:05.937|0670|.\3CXIvrService.cpp(892):IvrService, main(), Starting service, revision 7.0.3798.0
    21:39:06.000|0a9c|.\3CXIvrService.cpp(637):IvrService, MainServiceProc::Run(), Initializing php updater
    21:39:06.000|0a9c|.\3CXIvrService.cpp(646):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    21:39:06.000|0a9c|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    21:39:06.000|0a9c|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 7.0.3612.0
    21:39:06.140|0a9c|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    21:39:06.281|0a9c|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5484/ivr_start.aspx'
    21:39:07.609|0a9c|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    21:39:07.625|0af8|.\SLAgent.cpp(230):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    21:39:37.546|0af8|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[8000,8001][][]
    21:39:37.546|0af8|.\PbxMedia\IVREngine.cpp(869):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:9999
    21:39:38.125|0af8|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8000
    21:39:38.125|0af8|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8001
    21:39:38.125|0af8|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    01:22:30.390|1974|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=9999&IVRHandlerTO=9999&ISID=From_1314_To_9999_Menu_9999_%230%2F0MethodGETError-1
    01:22:30.390|1974|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:22:30.390|1974|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=9999&IVRHandlerTO=9999&ISID=From_1314_To_9999_Menu_9999_%230%2F0
    01:22:30.390|1974|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:22:34.609|1974|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    01:24:28.265|0af8|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[8000,8001][][]
    01:24:28.265|0af8|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    01:24:33.781|0af8|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[8000,8001][][]
    01:24:33.781|0af8|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    01:38:51.593|144c|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=9999&IVRHandlerTO=9999&ISID=From_1314_To_9999_Menu_9999_%230%2F1MethodGETError-1
    01:38:51.593|144c|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:38:51.593|144c|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=9999&IVRHandlerTO=9999&ISID=From_1314_To_9999_Menu_9999_%230%2F1
    01:38:51.593|144c|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:38:56.343|144c|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    01:41:26.000|1880|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F2MethodGETError-1
    01:41:26.000|1880|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:41:26.000|1880|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F2
    01:41:26.000|1880|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:41:30.718|1880|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    01:43:24.015|1760|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F3MethodGETError-1
    01:43:24.015|1760|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:43:24.015|1760|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F3
    01:43:24.015|1760|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:43:28.593|1760|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    01:44:09.578|17cc|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1315&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1315_To_8000_Menu_8000_%230%2F4MethodGETError-1
    01:44:09.578|17cc|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:44:09.578|17cc|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1315&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1315_To_8000_Menu_8000_%230%2F4
    01:44:09.578|17cc|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:46:39.640|11e4|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8001&IVRHandlerTO=8001&ISID=From_1314_To_8001_Menu_8001_%230%2F5MethodGETError-1
    01:46:39.640|11e4|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:46:39.640|11e4|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8001&IVRHandlerTO=8001&ISID=From_1314_To_8001_Menu_8001_%230%2F5
    01:46:39.640|11e4|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:46:44.359|11e4|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    01:50:43.093|1aa0|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F6MethodGETError-1
    01:50:43.093|1aa0|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc2
    01:50:43.093|1aa0|(0):Error! Module '3CX.com.vxi'. Error ID 203. urihttp://localhost:5484/ivr_start.aspx?IVRHandlerFROM=1314&IVRHandlerMENU=8000&IVRHandlerTO=8000&ISID=From_1314_To_8000_Menu_8000_%230%2F6
    01:50:43.093|1aa0|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    01:50:47.734|1aa0|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB68 not found
    02:00:10.984|0bb8|.\PbxMedia\IVRSLServer.cpp(27):SL: disconnected lamsoft-server:5482/CallManager at [lamsoft-server:5482]/CallManager
    02:00:11.109|0a9c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:9999
    02:00:11.109|0a9c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:8000
    02:00:11.109|0a9c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:8001
    02:00:11.437|0a9c|.\3CXIvrService.cpp(769):IvrService, MainServiceProc::Run(), Service stopped
    02:00:11.437|04d0|.\VxmlService.cpp(48):IvrService, CVxmlService::Run(), Service procedure completed with code 0
    Code:
    2009/01/25 >>
    02:15:40.875|181c|.\3CXIvrService.cpp(892):IvrService, main(), Starting service, revision 7.0.3798.0
    02:15:40.890|032c|.\3CXIvrService.cpp(637):IvrService, MainServiceProc::Run(), Initializing php updater
    02:15:40.890|032c|.\3CXIvrService.cpp(646):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    02:15:40.890|032c|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    02:15:40.890|032c|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 7.0.3612.0
    02:15:40.906|032c|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files (x86)\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    02:15:40.906|032c|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:81/ivr/ivr_start.aspx'
    02:15:40.953|032c|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    02:15:40.984|0c04|.\SLAgent.cpp(230):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    02:15:52.640|0c04|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[8000,8001][][]
    02:15:52.640|0c04|.\PbxMedia\IVREngine.cpp(869):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:9999
    02:15:53.437|0c04|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8000
    02:15:53.437|0c04|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8001
    02:15:53.437|0c04|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    02:16:05.046|0bc0|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:81/ivr/(S(q2hsp155qc2w5sjcgxc3gd45))/root.vxmlMethodGETError-404
    02:16:05.062|0bc0|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc50
    02:16:05.062|0bc0|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriroot.vxml
    02:16:05.062|0bc0|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    02:16:10.468|0bc0|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB80 not found
    02:19:10.250|1254|(0):Error! Module '3CX.com.OSBinet'. Error ID 219. URLhttp://localhost:81/ivr/(S(1vbajh552pgdusvmavbrit45))/root.vxmlMethodGETError-404
    02:19:10.250|1254|(0):Error! Module '3CX.com.OSBinet'. Error ID 204. rc50
    02:19:10.250|1254|(0):Error! Module '3CX.com.vxi'. Error ID 203. uriroot.vxml
    02:19:10.250|1254|.\api\VXIpromptImpl.cpp(212):IvrDll, VXIpromptImpl::Impl::Queue(), Error! A serious error within IVR session
    02:19:15.843|1254|.\VXIMachine.cpp(1704):IvrDll, VXIMachine::EndSession(), Warning! Session 0x0120FB80 not found
    02:19:31.781|032c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:9999
    02:19:31.781|032c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:8000
    02:19:31.781|032c|.\PbxMedia\IVREngine.cpp(986):IvrService, IVREngine::UnregisterLines(), Unregistering DN:8001
    02:19:31.859|0fa8|.\PbxMedia\IVRSLServer.cpp(27):SL: disconnected lamsoft-server:5482/CallManager at [lamsoft-server:5482]/CallManager
    02:19:32.468|032c|.\3CXIvrService.cpp(769):IvrService, MainServiceProc::Run(), Service stopped
    02:19:32.468|06bc|.\VxmlService.cpp(48):IvrService, CVxmlService::Run(), Service procedure completed with code 0
    There is no web listening at localhost:5484, is it possible to change it to localhost/ivr/ ? thanks.
  3. lamsoft
    Jan 23, 2009
    12
    It seems that 3CX installer does not know the Windows XP x64 is based on Windows 2003 Kernel but IIS is limited to 1 web site only.
    It will cause all the IVR session fail, such as voicemail, digital receptionist, etc...
    however when i installed with the bundled webserver, the ivr has error too...... weird (i have install and reinstall couple of times today already....)
    Code:
    2009/01/25 >>
    19:50:33.421|15c0|.\3CXIvrService.cpp(892):IvrService, main(), Starting service, revision 7.0.3798.0
    19:50:33.421|0604|.\3CXIvrService.cpp(637):IvrService, MainServiceProc::Run(), Initializing php updater
    19:50:33.421|0604|.\3CXIvrService.cpp(646):IvrService, MainServiceProc::Run(), Writing global parameters to php ...
    19:50:33.421|0604|.\IVR_Api.cpp(631):IvrDll, Ivr_SetLog(), External log has been set for IVR dll
    19:50:33.421|0604|.\IVR_Api.cpp(311):IvrDll, IVRApi::Init(), Initializing, revision 7.0.3612.0
    19:50:33.437|0604|.\IVR_Api.cpp(172):IvrDll, IVRApi::LoadConfiguration(), Using config file 'C:\Program Files\3CX PhoneSystem\Bin\..\Data\Ivr\Cfg\3CXIvr.cfg'
    19:50:33.437|0604|.\IVR_Api.cpp(206):IvrDll, IVRApi::LoadConfiguration(), Default vxml document: 'http://localhost:5484/ivr_start.aspx'
    19:50:33.531|0604|.\3CXIvrService.cpp(728):IvrService, MainServiceProc::Run(), Service started
    19:50:33.546|0ff8|.\SLAgent.cpp(230):IvrService, SLAgent::Run(), Reconnected to 127.0.0.1:5482 SL server
    19:50:40.500|0ff8|.\PbxMedia\IVREngine.cpp(853):IvrService, IVREngine::RegisterLines(), Registering of lines...127.0.0.1:5060127.0.0.1:50609999[8000,8001][][]
    19:50:40.500|0ff8|.\PbxMedia\IVREngine.cpp(869):IvrService, IVREngine::RegisterLines(), Registering SpeciaMenu:9999
    19:50:41.468|0ff8|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8000
    19:50:41.468|0ff8|.\PbxMedia\IVREngine.cpp(907):IvrService, IVREngine::RegisterLines(), Registering IVR:8001
    19:50:41.484|0ff8|.\PbxMedia\IVREngine.cpp(978):IvrService, IVREngine::RegisterLines(), Registering of lines done.
    20:06:44.671|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000
    20:06:49.093|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:06:52.218|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:06:55.265|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:06:58.359|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:01.390|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:04.437|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:07.546|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:10.593|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:13.656|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:16.718|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:19.765|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:22.812|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:25.937|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:29.000|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:32.046|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:35.093|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:38.156|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:41.218|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:44.265|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:47.343|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:50.375|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    20:07:53.437|064c|(0):Error! Module '3CX.com.OSBinet'. Error ID 302. URLhttp://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1
    Code:
    20:07:53.437|064c|.\api\VXIrecImpl.cpp(428):IvrDll, VXIrecImpl::Impl::Recognize(), Recognition stopped
    20:07:53.437|064c|(0):Subtag SBjsiEval. entering: 0x02D42FF8, 'application.waveform$ = null;', 0x00000000
    20:07:53.437|064c|(0):Subtag SBjsiEval. exiting: returned 0, 0x00000000 (0x00000000)
    20:07:53.437|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, '$_execAnonymous_'
    20:07:53.437|064c|(0):Subtag SBjsiPushScope. exiting: returned 0
    20:07:53.437|064c|(0):Subtag SBjsiSetVarValue. entering: 0x02D42FF8, '_event', 0x02D310B0
    20:07:53.437|064c|(0):Subtag SBjsiSetVarValue. exiting: returned 0
    20:07:53.437|064c|(0):Subtag SBjsiSetVarValue. entering: 0x02D42FF8, '_message', 0x02D2A490
    20:07:53.437|064c|(0):Subtag SBjsiPopScope. entering: 0x02D42FF8
    20:07:53.437|064c|(0):Subtag SBjsiPopScope. exiting: returned 0
    20:07:53.437|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, 'local'
    20:07:53.437|064c|(0):Subtag SBjsiSetVarExpr. entering: 0x02D42FF8, 'timed_out', 'true'
    20:07:53.437|064c|(0):Subtag SBjsiSetVarExpr. exiting: returned 0
    20:07:53.437|064c|(0):Subtag SBjsiSetVarExpr. entering: 0x02D42FF8, 'dn_fwd', '8000'
    20:07:53.437|064c|(0):Subtag SBjsiSetVarExpr. entering: 0x02D42FF8, 'transfToIVR', 'true'
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'act', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. exiting: returned 2, 0x0300F4E8 (0x00000000)
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_0', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_1', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_2', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_3', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_4', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_5', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_6', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_7', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_8', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_9', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'Action_star', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'timed_out', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0300F4E8 (0x02D2A490)
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'transfToVM', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'transfToIVR', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. exiting: returned 0, 0x0300F4E8 (0x02D344A0)
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'transfToDN', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'doTransfer', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'repeat', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiGetVar. entering: 0x02D42FF8, 'blkExit', 0x0300F4E8
    20:07:53.437|064c|(0):Subtag SBjsiEval. entering: 0x02D42FF8, ''dr.aspx?dr='+dn_fwd', 0x0300F440
    20:07:53.437|064c|(0):Subtag SBjsiEval. exiting: returned 0, 0x0300F440 (0x02D310B0)
    20:07:53.453|064c|(0):Subtag SBjsiPopScope. entering: 0x02D42FF8
    20:07:53.453|064c|(0):Subtag SBjsiPopScope. exiting: returned 0
    20:07:53.453|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, 'document'
    20:07:53.453|064c|(0):Subtag SBjsiPushScope. exiting: returned 0
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'dn_len', '4'
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. exiting: returned 0
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'dn_fwd', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'user_param', ''''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'trprompt', '1'
    20:07:53.453|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, 'dialog'
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'act', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_0', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_1', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_2', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_3', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_4', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_5', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_6', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_7', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_8', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_9', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'Action_star', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'timed_out', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'transfToVM', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'transfToIVR', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'transfToDN', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'doTransfer', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'repeat', ''
    20:07:53.453|064c|(0):Subtag SBjsiCreateVarExpr. entering: 0x02D42FF8, 'blkExit', ''
    20:07:53.453|064c|(0):Subtag SBjsiCheckVar. entering: 0x02D42FF8, 'act'
    20:07:53.453|064c|(0):Subtag SBjsiCheckVar. exiting: returned 1
    20:07:53.453|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, 'local'
    20:07:53.453|064c|.\api\VXIpromptImpl.cpp(132):IvrDll, VXIpromptImpl::Impl::Queue(), baseUrl = 'http://localhost:5484/(S(eblr4155joc5nt45pwcoab45))/dr.aspx?dr=8000&timed_out=1&transfToIVR=1'
    20:07:53.453|064c|.\api\VXIpromptImpl.cpp(240):IvrDll, VXIpromptImpl::Impl::Queue(), Queuing AUDIO: C:\Program Files\3CX PhoneSystem\Data\Ivr\Prompts\01.wav
    20:07:53.468|064c|.\api\VXIrecImpl.cpp(304):IvrDll, VXIrecImpl::Impl::Recognize(), Recognition started
    20:07:53.500|0d10|.\VXIMachine.cpp(1254):IvrDll, CallSession::PromptPlayed(), Prompt 24 played
    20:07:53.500|0d10|.\VXIMachine.cpp(338):IvrDll, CallSession::PromptsMap::PromptPlayed(), All prompts played
    20:07:54.015|0e6c|.\VXIMachine.cpp(1712):IvrDll, VXIMachine::EndSession(), Removing From_1315_To_8000_Menu_8000_#0/2 call
    20:07:54.015|0e6c|.\SmpThread.cpp(95):IvrDll, CSmpThread::Stop(), stopping thread 0x0000045C
    20:07:54.015|064c|.\api\VXIrecImpl.cpp(428):IvrDll, VXIrecImpl::Impl::Recognize(), Recognition stopped
    20:07:54.015|064c|(0):Subtag SBjsiEval. entering: 0x02D42FF8, 'application.waveform$ = null;', 0x00000000
    20:07:54.015|064c|(0):Subtag SBjsiEval. exiting: returned 0, 0x00000000 (0x00000000)
    20:07:54.015|064c|(0):Subtag SBjsiPushScope. entering: 0x02D42FF8, '$_execAnonymous_'
    20:07:54.015|064c|(0):Subtag SBjsiPushScope. exiting: returned 0
    20:07:54.015|064c|(0):Subtag SBjsiSetVarValue. entering: 0x02D42FF8, '_event', 0x02D262C8
    20:07:54.015|064c|(0):Subtag SBjsiSetVarValue. exiting: returned 0
    20:07:54.015|064c|(0):Subtag SBjsiSetVarValue. entering: 0x02D42FF8, '_message', 0x02D470B8
    20:07:54.015|064c|(0):Subtag SBjsiDestroyContext. entering: 0x02D4153C (0x02D42FF8)
    20:07:54.031|064c|(0):Subtag SBjsiDestroyContext. exiting: returned 0
    20:07:54.031|064c|(0):Subtag SBjsiDestroyContext. entering: 0x02D23E84 (0x0120FD80)
    20:07:54.031|064c|(0):Event occurred (ID # 1).
    20:07:54.031|064c|.\api\VXItelImpl.cpp(83):IvrDll, VXItelImpl::Impl::EndSession(), EndSession
    20:07:54.031|064c|(0):Subtag VXIplatformProcessDocument. exiting: rc = 0, 0x00000000
    20:07:54.031|064c|(0):Subtag ChannelThread. NULL result
    20:07:54.031|0e6c|.\QueueDataMgr.cpp(92):IvrService, QueueDataMgr::UnregisterCall(), Unregistering 'From_1315_To_8000_Menu_8000_#0/2' call
    20:07:54.031|0e6c|(0):Subtag SBjsiDestroyResource. entering: 0x0120ED7C (0x02D428A8)
    20:07:54.031|0e6c|(0):Subtag SBjsiDestroyResource. exiting: returned 0
    20:07:54.031|0d48|.\3CXIvrService.cpp(100):IvrService, PhpUpdater::TaskCheckMenus::Execute(), Checking IVR menus
    Here is the ASP.NET Error...
    [​IMG]
    I hope someone could help me... thanks a lot...
    ps: extension 8000 is a digital receptionist
  4. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Which v7 build are you installing? 4744?
    Mike
  5. lamsoft
    Jan 23, 2009
    12
    Yes.
    3CX Phone System v7.0.4744.0
  6. NRG
    NRG
    Dec 24, 2008
    31
    I also get this error
  7. worksighted
    Aug 19, 2008
    204
  8. Discovery Technology
    Apr 19, 2008
    278
    I noticed this on a V7 installation recently which still persisted after upgrading to V8.
    After looking into it for a bit, I noticed a W3SVC error in the system event log that mentioned something about one of the web services not starting, then I noticed 2 instances of the IVR virtual website, the second one was stopped (this was in IIS on a Windows 2003 Server)
    I uninstalled V8, deleted the remaining IVR web site that was running after the uninstall, ran the installation checker then reinstalled and it worked perfectly. I suspect it would also work if yo left your phone system version at V7.
    This should get your voicemail working again and appears to be an indication that the IVR virtual website is probably not started due to a listening port clash on 5484.
  9. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,557
    118
    Version 8 Only works with Version 3.5 of Net Framework. If you have 2.0 uninstall it and get 3.5.
    And if you have Version 7, it's still recommended that you install Net Framework 3.5 because it solves some smelly IVR issues.
    Get it here: http://www.microsoft.com/downloads/details.aspx?FamilyID=AB99342F-5D1A-413D-8319-81DA479AB0D7&displaylang=en
