neilhooper
- Joined
- Jul 12, 2014
- Messages
- 27
- Reaction score
- 2
3CXv12
Hi Everybody,
I, like so many others it seems, want to be able to choose which line is used when dialling out on PSTN lines using Patton SN4xxx FXO gateways.
Using some advice from an indirect source to a 3cx partner we have come up with a solution so I thought I would share it with everybody.
This is what I did to get it all working and some of the problems along the way.
1. After successfully installing 3cx and getting softphone extensions to work, some Windows and some Android. I installed the Patton. I went through the normal Add a Gateway Wizard and created the configuration file to upload to the Patton. At first all seemed well; I could dial in on each line without problem and answer and talk to the 'caller' (myself).
2. First problem. When trying to dial out the calls would fail with messages in the Log about Bad Gateways and Timeouts. I'm not going to post the full error messages here, you'll know them when you see them.
3. After searching on these forums I discovered that I needed to add two extra lines to the configuration on the Patton in this section.
The two lines are exactly the same they are : dial-after timeout 2
That cured the first problem. I could dial out.
4. Next problem, as far as I'm concerned, and quite a few others as far as I can see; is like others, I'm using 3cx at home with a Business line and a Private line. When I dialled out, the first available line was always used and there was no way of selecting any other. My very short term solution was to grab the first line using an extension and then dial out on the next available one which was OK but frustrating, and I've only got two lines. I know a lot of people have four or more.
5. Now the tricky bit. I created another Patton Gateway. My first one had Ports 10000 and 10001. My second one had Ports 10004 and 10005. Basically all references to 10001 need to be replaced with 10004 in the Patton configuration. To do this I exported the Running Configuration and edited it. I also knew that I need to change the password for Port 10004 as it would never register as the password was still the password for Port 10001. The problem is that the password in the configuration file is encrypted and of course we don't know how to encrypt it. This is where it gets long winded. I created the configuration file for the second gateway in 3cx. I then imported it into the Patton and then exported it back out.
In this section :
You will find the encrypted passwords for the Ports. I've removed my passwords for security.
I copied the password for Port 10004 and pasted it into my original configuration file so it now looks like this :
I then imported the saved, original configuration file back into the Patton.
This was a little time consuming and as I have already said, I've only got two lines.
I can't see why this method wouldn't work for 4 lines etc.
By creating some outgoing rules I am now able to select which line I dial out on as the two Patton devices show up in the Outgoing rules. I've used the prefixes of 7 and 8 to differentiate between the two lines.
One thing to remember, check the IP Blacklist in Settings - Security along the way as you may find out that during your time doing this the Patton may try to register when it can't and may get Blacklisted.
I hope this helps somebody.
- Neil
PS. The only problem I now have is how to dial a 7 or 8 and then a number from the phone book; but that's another day !!!
Hi Everybody,
Code:
interface fxo IF_FXO_0
route call dest-interface IF_SIP_0
loop-break-duration min 60 max 1000
disconnect-signal loop-break
disconnect-signal busy-tone
ring-number on-caller-id
mute-dialing
interface fxo IF_FXO_1
route call dest-interface IF_SIP_1
mute-dialing
In this section :
Code:
authentication-service AS_ALL_LINES
realm 1 3CXPhoneSystem
username 10004 password xxxxxxxxxxxxxxxxxxxxxx== encrypted
username 10005 password xxxxxxxxxxxxxxxxxxxxxx== encrypted
Code:
username 10000 password xxxxxxxxxxxxxxxxxxxxxx== encrypted
- Neil
