Assistance Request
Discussion in '3CX Phone System - General' started by alonchu, Feb 1, 2011.
  1. alonchu
    Jul 18, 2008
    21
    Hello Everyone!
    I am in need of assistance with a project I am trying to complete.
    I have a 3cx PBX running with a Grand Stream 4108 transferring my Verizon lines to the 3cx.
    I am trying to create a virtual extension on the system (IE: ext. 666) once dialed this extension will give a dial-tone to dial out of the 3cx.
    I am trying to do this for 2 reasons:
    1. I have people traveling abroad all the time. We have local numbers around the world and this will allow them to use our system to call anywhere using our line and only dial a local number.
    2. I also have great international calling plans on our lines and would like to give my employees the ability to use these plans from their cellphones and home phones.
    Does anybody have an idea on how I can do this?
    I would assume there is a softphone that I can configure to do this.
    Thanks,
    Alon.
  2. mattlandis
    Nov 9, 2007
    12
    You are looking for DISA. Currently not a feature but you can vote for it here:
    http://3cx.ideascale.com/a/dtd/Real-DISA-trunk-access/71757-9854
  3. leejor
    11,283
    360
    While we wait...A Linksys SPA3102 has the ability to authenticate (PIN or Caller ID) a call in on VoIP and then out on PSTN (I think It will do it vice versa as well) if you only plan on having one call up at a time. It could be used in conjunction with 3CX but one side is a PSTN line.
  4. mattlandis
    Nov 9, 2007
    12
    Hi leejor,
    thanks for that tip.
    wow, i see you are active on the forums! ;-)
    Matt
