assistant dialing +44
Discussion in '3CX Phone System - General' started by jemscott, May 20, 2011.
  1. jemscott
    Jun 7, 2010
    8
    Can you please advise if there is a fix for dailign form Outlook when the number is prefixed with +44 or any other international dailign code as I get call failed....
    Jeremy
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    when dialing ensure there is no + just 44 and that should work, you may need to look at your outbound rules.
  3. jemscott
    Jun 7, 2010
    8
    But the numbers come from Outlook and sync to BlackBerry that needs the + to dial the number !!
    That is the conflict
  4. davidbenwell
    Apr 27, 2010
    704
    create a outbound rule within 3CX with a call prefix of +
    set the correct route and where it says Strip Digits select 1
    move the rule to the top of the list
    see if that works
  5. Luis Santos
    Jul 17, 2017
    18
    Also, keep in mind to check you E164 rules:
    3cx Admin -> Settings -> E164 Processing
    Make sure to select:
    United Kingdom: +44
    check - remove if same country
    International Dial Code: 00
    National Dial Code: 0
    those settings did it for me, thus outbound rules considered irrelevant in this scenario for formatting the number.
    Furthermore, a +44 rule would show up as 01144 when hitting the outbound rules.
    If you require any help, message me.
