Assistant external program notification parameters
Discussion in '3CX Phone System - General' started by benjamincuningham, Sep 13, 2013.
  1. benjamincuningham
    Sep 13, 2013
    Is there a list somewhere of the parameters that can be passed to an external program by the Assistant on incoming calls? In particular, I would like anything that contains the name or part of the name of the caller. The only parameter that I can find is the default %callid%, which is just the extension.
