Assistant not working on version 10
Discussion in '3CX Phone System - General' started by sdiazdefalco, May 17, 2012.
  1. sdiazdefalco
    Oct 13, 2009
    19
    Hello all!
    I have updated from 9v to the latest release of the 10th and all the provisioned phones stopped working and the 3CX Assistant stopped working as well.
    I noticed that when I resend the welcome email to the extensions the provisioning URL changed the port from 5481 to 5000
    I always had problems with the Assistant.
    Does anyone here suffered the same when updating? I am not on the 11b version and seriously considering not updating to it until I read more of it...
    Thanks in advanced!
    Sebastian!
  2. paul.hadley
    paul.hadley New Member
    Aug 24, 2010
    122
    I think in V10 the provisioning URL was changed from port 5481 to 5000
    To get the phones working again change the address they provision from to port 5000 (Replace 5481 with 5000)
    The same with the assistant, the new address is http://(your server IP):5000/MyPhone
    In V11 the settings remain the same as V10, so once you have made the changes for V10 it won't be a problem when you upgrade to V11
  3. active5
    Jun 28, 2011
    72
    The 3CX Assistant was discontinued with version 10 and replaced with 3CX MyPhone.
    It is my understanding that the 3CX Assistant does not work on V10.
  4. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    Why are you not using 3cxmyphone?
  5. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    Somebody needed to read the release notes and stickys about upgrading to v10.
  6. sdiazdefalco
    Oct 13, 2009
    19
    I had no clue what Myphone was, I see that 3CX assistant has been discontinued so that's the reason it stoped working.
    I have some issues with MyPhone but I will post about that in another thread
    Thank you all for the orientation!
