assistant update
Discussion in '3CX Phone System - General' started by zman574, Jul 19, 2010.
  1. zman574
    Jun 24, 2010
    57
    Is there a way to resend out the assistant provisioning to users automataclly without setting up the extensions again. what i mean is i have an extension say 100 that is set up, i installed version 9 and that has a different assistant needed for ext100 to work, I want to send out a new welcome email to the user without having to create the extension again? I dont see this option anywhere and changing the extension does not seam to trigger the email to be sent again.
    Jim
  2. carolinainnovative
    May 4, 2009
    369
    6
    There is a button "Send Welcome Email" - it is in the extensions screen. See this post for a screen shot:
    http://www.3cx.com/forums/rc1-where-did-resend-activation-email-go-15830.html
  3. zman574
    Jun 24, 2010
    57
    Thanks that was exactly what I was looking for.
