Assistant V9 EXE Dial, how in myphone desktop components
Discussion in '3CX Phone System - General' started by dbeyzade, May 26, 2011.
  1. dbeyzade
    Jan 18, 2011
    7
    Hi All,
    In V9 assistant our company used the “c:\program files\3cx assistant\tcx.assistant.client.exe” -cmd makecall:123456789 to dial numbers from our database system filemaker pro.
    After upgrading to v10 for the resolve caller ID from company phonebook feature, I cannot find out to use this feature with the v10 myphone desktop components
    Would anybody have a solution, although I have a suspicion this function has been removed
    Daniel
  2. dbeyzade
    Jan 18, 2011
    7
    No one has an answer to what has happened to this feature?
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    It went away for now. If you need it you cannot upgrade to v10 yet.
