ATA Flash transfer
Discussion in '3CX Phone System - General' started by Philco, Dec 24, 2007.
  1. Philco
    Philco Member
    Nov 10, 2007
    364
    Not sure if his is a common problem wih 3CX and ATAs, but I have a Grandstream HT486 and a HT488 ATA from which I am sure I could transfer calls to another extension using the recall/flash button on the analogue phone. This ability seems to have disapeared on V5 and I am sure was ok on V3.
    Has anyone else noticed this please.
    Phil
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    It should not be the issue of V3 or V5. The issue should be from the recall/flash button on the analogue phone.
    My ATA list:
    Grandstream HT488
    GrandstreamHT503
    Netgear TA612V
    Analogue phones tested result:
    Panasonic DECT phones: works fine at both V3 or V5
    Uniden DECT phones: works fine at both V3 or V5
    Siemens DECT phone: Failed at both V3 or V5
    NEC wired analogue phone: Failed at both V3 or V5
  3. Philco
    Philco Member
    Nov 10, 2007
    364
    Thanks Ricky, I wouldnt have thought it was 3CX either, but I am sure it worked fine on V3.
    What firmware is your HT488?
    The analogue phone does give a 'flash' condition when he recall button is pressed which is observed on he phone display.
    Regards
    Phil
  4. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    My HT488's firmware 1.0.3.86
  5. Philco
    Philco Member
    Nov 10, 2007
    364
    Thanks Ricky, I'm on 1.0.3.96 and I didnt keep a copy of 1.0.3.86.
    The thought has just crossed my mind that on my test bench I may have used a pair of BT phones rather than the Audioline pair I have now. BT would conform to the standard and deffinitly worked.
    I'm assuming (incorrectly) that they should work as they are simply providing a normal recall/LD signal.
    Regards
    Phil
