ATA for Fax
Discussion in '3CX Phone System - General' started by jpillow, Aug 18, 2013.
  1. jpillow
    jpillow Well-Known Member
    Jun 20, 2011
    1,342
    I've used a few different ATA's some with luck sometimes others not so much, does anyone have a solid ATA for fax solution?
    10,726
    275
    I've had luck using an SPA-2102 out over PSTN via a 3102. A VoIP provider that I just began using does not seem to support fax (no T.38). An outside call reaches my machine, but it goes through all of the speeds, dropping finally to 2400 before giving up.
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Dont push fax through SIP or T.38... use HTTPS!!!!(which means not running this through 3cx server)
  4. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,083
    61
    jpillow -
    I have been using an ATA and Fax with reasonable success (both sending and receiving) for a few months now. PremierVoIP is capable of supporting multiple registrations to a singular account and as a result, where customers are insistent, I will register 3CX with one set of credentials and then use an ATA with another set (Grandstream HT502 in my case). 3cx never enters into the FAX picture and with T38 (allowed) set directly with the ATA, I get pretty good results.
    http://www.premiervoip.com
    https://premiervoip.com/
    I have tried using an ATA through 3CX and have limited success, but not nearly as much as this method.
    I am even able to use their solution over wireless networks, but I have never seen a "Solid" fax connection to include wired copper as they are all subject to some form of signal issues. There may be other providers who also support this, but I have yet to see anyone advertise as such.
  5. efounco
    efounco New Member
    Sep 28, 2011
    148
    A word of advice. If you need something reliable, either invest in a single analog line or pay for a http:// FAX service. FAX over VOIP is very unreliable with some FAX machines. It works OK with others...
  6. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Indeed, your initial statement is pretty much what my results were after hammering configs on a few different fax devices on a few different 3CX installs, sending or receiving faxes was "inconsistent" at best.. "epic fail" at worst. We started diversifying with different SIP trunks.. didn't help.
    PSTN is still the win if you need fax.. the freebie you get for a DSL circuit to run VOIP over seems to work fairly well.. for those who cannot "let go" of fax.
  7. bardissi
    bardissi Member
    Jan 31, 2012
    318
    I actually dont agree that the PSTN is the only true way to handle fax. We have over 150 HTTPS Fax ATA's out there and we have 100% success rate.
  8. countrycomp
    Dec 2, 2008
    53
    Which ATA's are you using for HTTPS ?
  9. jpillow
    Jun 20, 2011
    1,342
    As a general rule of thumb we tell clients to use copper for analog devices, however I've been on the lookout for an ATA that will register to the pbx and send and receive fax via t38 from the voip provider. Still nothing 100% .. :S
  10. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Dont bother looking for a solid T38 device to connect back to the PBX and work well.
    It doesnt exsist.
    Look for a solution that handles fax via HTTPS.
    We have over 200 HTTPS fax units out there and they are perfect!
  11. jpillow
    Jun 20, 2011
    1,342
    Thanks for the responses I guess it will continue to be an analog line as always.
