ATA Question
Discussion in '3CX Phone System - General' started by dyntech, Apr 6, 2007.
  1. dyntech
    dyntech New Member
    Mar 28, 2007
    160
    If I had a basic D-Link or Sipura ATA, is it possible to configure 3CX to use this as a VOIP Gateway or do I need an actual "Gateway" device?
  2. wewake
    Apr 5, 2007
    10
    I have tried SPA3102, it works fine
  3. Anonymous
    Anonymous Guest
    The Sipura (SPA3102 is very good) is your VoIP gateway it can receive calls from the PSTN and make calls to your VoIP provider via the internet.
    So a common setup is:
    Internet gateway this is your modem and connects to your ISP.
    VoIP gateway, can be part of you modem for phone calls via your ISP (or VSP).
    PSTN gateway is an ATA device that accepts calls from the PSTN and converts this to VoIP.
    THe SPA is a voip and PSTN gateway.
    HOpe this helps.
    Henk
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,992
    308
    Anything that has so called FXO ports is a VOIP Gateway. The ones you are referring to are often limited to 1 or 2 lines, but they are still a Gateway.
    if you want to connect PSTN lines, you need to ensure that the device you are getting has FXO ports. Just in case:
    http://www.3cx.com/PBX/FXS-FXO.html
