ATA won't connect on UDP
Discussion in '3CX Phone System - General' started by Peter Richardson, Jun 18, 2017.
  1. Peter Richardson
    Peter Richardson New Member
    Apr 6, 2017
    149
    5
    Hi all,
    I'm using a Cisco SPA112. I can't get it to register with 3CX using UDP in the ATA. I have attached the settings I have used. I have enabled "use of extension outside the LAN". I have forwarded TCP and UDP on port 5060 to the PBX on the firewall. I'm not sure what else to check. Any ideas?
  2. Brad Cann
    Brad Cann New Member
    May 5, 2017
    106
    12
    you need to connect the ata via the WAN port not the LAN port.
    EDIT
    Whoops saw your model as 122 not 112. you need to set the fax up under fax extensions not extensions.
    Been there done that :)
  3. leejor
    10,368
    228
    When your device attempts registration, what shows in the 3CX Activity Log? Does an attempt show up? If so, are there error messages, reasons it is rejected?
  4. Peter Richardson
    Apr 6, 2017
    149
    5
    Thanks guys. I'll check the error logs. Can anyone tell me what the advantage or point is of setting it up through the "fax extensions" section? How exactly does 3CX handle the registration from the ATA differently? Etc.
  5. Peter Richardson
    Apr 6, 2017
    149
    5
  6. Brad Cann
    May 5, 2017
    106
    12
    not 100% but probably enables the fax codec support, IE t.38. all i know is mine works 100% as a fax extension once the ata had t.38 enabled.
  7. Peter Richardson
    Apr 6, 2017
    149
    5
    Thanks Brad!
    Anyone else know what the "fax extension" actually does behind the scenes?
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,443
    282
    Fax extensions give you the option of T38 support. Where a normal extension cannot support T.38 a fax extension can as it is "bound" to the fax server of the PBX.
  9. Peter Richardson
    Apr 6, 2017
    149
    5
    But this automatically sets the extension to "disable outside LAN" (which is not an option but we can see in the logs that it is being blocked). 3CX is touted as a "cloud PBX" but it can't even run a basic fax machine unless it's on the LAN. This is an absolute disgrace. I can't believe that every 3CX customer is denied using fax machines.
  10. Brad Cann
    May 5, 2017
    106
    12
    how many people have a fax machine in their office connected to a cloud pbx for outbound through a wan? Why would you just not use a sip trunk to carry it rather then go out through your wan to go into someone elses (IE Hosted PBX Provider) wan to then go back out again? Just set it the way you've been told and it works just fine. we probably send ~ 20 faxes a week without issue through our xerox copier/fax machine via the same ata you use...
  11. Peter Richardson
    Apr 6, 2017
    149
    5
    So you're suggesting that we bypass 3CX altogether for the fax ATA? We provide VoIP services to our customers and we use 3CX to do this. Having complex and custom routes for every customer would get messy very quickly.
  12. Brad Cann
    May 5, 2017
    106
    12
    i don't know your config, but with our config (Hosted internally), we merely just setup a Fax extension through the fax extension tab, and registered it through the ATA to our internally hosted PBX, and made sure the appropriate settings were turned on on the ATA (T38/fax stuff). If your cloud hosted, i don't know how it would work, but i'd imagine the only real difference is the IP address your registering your ATA to.
    Create the extension through Fax extensions, NOT phone extensions.
    Otherwise just register your ata through some local sip provider who supports fax.
  13. Peter Richardson
    Apr 6, 2017
    149
    5
    That's fine for an internally based service, as what you have. But that is not what we provide our customers. We provide a cloud hosted PBX service for our customers.
    As I said before, we have done this but 3CX is blocking our extension that we have indeed created under Fax Extensions with an error about it blocking connections from outside the LAN.
    We don't want to have multiple providers for every customer that wants a fax machine, this makes things unnecessarily complex.
  14. Peter Richardson
    Apr 6, 2017
    149
    5
    So has anyone on this planet been able to successfully get a fax machine to work with a cloud hosted 3CX?
  15. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,061
    56
    No, and unlikely until 3CX will allow it outside the LAN given your current configuration. Your other option might be to try a VPN between sites. t.38 is not foolproof and while it may function as intended, it is mostly dependent on a reliable and stable end to end internet connection. In my area, we are not blessed with a plethora of ISP providers from which to choose and while many will handle the HTTP and like traffic fine, RTP is another matter. As a result, and after years of trying with every ATA known to man (I think), I have moved to fax using HTTPS. Yes, another registration and a higher initial cost (device) than the ATA, but usually able to recover the device cost over POTS line cost in about 12 months or so as the monthly service for some HTTPS providers is cheaper than a monthly POTS. So far, in over 3 years of use with numerous clients, it has proven to be every bit as reliable as copper.
    While the ATA may be fine in your scenario, the HTTPS may be your only real hope if the other does not work out ; even if using VPN, 3CX allows or getting a separate ATA registration.
  16. us1
    us1
    Oct 19, 2015
    80
    21
    I gave up on setting up an ATA for fax via 3CX. Now I just create a separate sub account with my SIP provider, attach the fax number to that sub account, and register the ATA directly with the SIP provider. It saves some hops, has fewer "opportunities" for problems, and has been much more reliable.
  17. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    I'm using AudioCodes Mediant MP-112 in my office remotely to a cloud 3CX server into a data-center with 100% success rate for several years already. The SIP provider is supporting only T.38 fax. I have an IPsec VPN between my office and the data-center.
  18. Peter Richardson
    Apr 6, 2017
    149
    5
    Thanks very much @sip.bg I'll buy one of these and let you know how I go!
  19. sip.bg
    Nov 7, 2016
    704
    219
    You still need VPN, otherwise 3CX will not register fax extension out-of-LAN.
  20. cobaltit
    cobaltit Active Member
    Mar 22, 2012
    734
    113
    So personally we only offer FoIP to clients we don't like and with a big disclaimer that we don't support it. We recommend all customers that actually care about faxing keep a POTS line for outbound faxing and we use 3CX built-in fax server for inbound. Other solutions are using the same provider handling PBX dialtone and routing the fax number to a 2nd trunk registered directly to the ATA. If you really want reliable FoIP then you go AudioCodes HTTPS faxing but that will most likely require a second provider.
