ATCOM & 3CX
Discussion in '3CX Phone System - General' started by laki, Feb 11, 2007.
  1. laki
    Feb 11, 2007
    Hi all,
    I have 15 extensions on my 3cx, 14 off them are software phones (x-lite), 5 are in Serbia where my 3cx and 9 are in Canada. Everything works fine, but yesterday I have tryed to connect one hardware phone (atcom 320), and I have problem calling extensions in Canada, I can not hear them, with extensions in Serbia every thing work's fine? Can somebody help me with this?
    thanks!
  2. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Your problem description suggests network routing and/or firewall issues.
    In this scenario we suggest using a VPN connection.
    Further more the phone you are using is not in the list of supported phones. The list of tested phones can be found here
