Attaching an App to Outbound Calls
Discussion in 'CRM / Helpdesk / App Integration' started by Mullenlaw, Oct 20, 2011.
  1. Mullenlaw
    Apr 13, 2011
    53
    Is there any way to attach an application to an outbound rule?
    We'd like to capture some info under certain conditions when calling outbound.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Currently there is no way. VAD applications are triggered on inbound calls.
    But please make a new feature request on ideas.3cx.com.
    Regards,
  3. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    What are you trying to capture on outbound calls?
