Attended transfer doesn't work with GS-BT200
Discussion in '3CX Phone System - General' started by adams, Nov 12, 2007.
  1. adams
    Nov 12, 2007
    5
    I'm testing 3cx and all seems to work correctly. I have 5 BT200 Grandstream, 2 SPA 3102 and one voip provider configured.
    Unfortunately when I try to transfer a call, the call are always blind transfered: when the user on the remopte extension pickup the phone he get the call "directly"....
    How can I solve this Issue?
    Thank you
  2. Philco
    Philco Member
    Nov 10, 2007
    364
    Hi Adams, does this ocour if you put the call on hold first?
    Phil
