Attended transfer doesn't work
Discussion in '3CX Phone System - General' started by Ryandc, Aug 24, 2007.
  1. Ryandc
    Aug 13, 2007
    70
    Okay, here's the system config:
    SBS 2003 running Enterprise Edition 3cx
    Linksys SPA922 and 962 phones
    Grandstream 4108 Gateways.
    I saw this same problem posted elsewhere on the forums. However, there was no response, so here we go again, this time with a server log:
    Here's the error stack
    09:58:11.180 StratLink::eek:nHangUp [CM104001] Call(602): Ln:10004@Gateway1 hung up call; cause: BYE; from IP:192.168.0.161
    09:57:54.570 StratTransfer::eek:nConnected [CM008008] Call(603): Transfer: wrong leg is connected
    09:57:54.445 StratLink::Transfer [CM104002] Call(603): transfers Ln:10006@Gateway1 from Ext.201 to sip:205@192.168.0.12
    09:57:47.226 CallLegImpl::eek:nConnected [CM103001] Call(604): Created audio channel for Ext.205 (192.168.0.32:16464) with Media Server (192.168.0.12:7178)
    09:57:47.211 StratInOut::eek:nConnected [CM104005] Call(604): Setup completed for call from Ext.201 to Ext.205
    09:57:47.211 CallLegImpl::eek:nConnected [CM103001] Call(604): Created audio channel for Ext.201 (192.168.0.34:16386) with Media Server (192.168.0.12:7176)
    09:57:41.305 CallConf::eek:nProvisional [CM103003] Call(604): Ext.205 is ringing
    09:57:41.195 CallConf::eek:nIncoming [CM103002] Call(604): Incoming call from 201 (Ext.201) to sip:205@192.168.0.12
    09:57:37.742 MediaServerReporting::RTPSender [MS004000] Call(603) Ext.201: (ACTIVE): Can't send RTP stream to 0.0.0.0:16384 destination unreachable
    09:57:17.398 CallLegImpl::eek:nConnected [CM103001] Call(603): Created audio channel for Ext.201 (192.168.0.34:16384) with Media Server (192.168.0.12:7174)
    09:57:17.367 StratInOut::eek:nConnected [CM104005] Call(603): Setup completed for call from Ln:10006@Gateway1 to Ext.201
    Here's what happens: I call in. I then ask to be transferred. Attended transfer begins; I hear the hold music. Receptionist finishes the attended transfer and I begin speaking to the person to whom the call was transferred. After approximately 10-20 seconds, the call terminates.
    Thoughts, anybody?
    -Ryan
  2. dete
    Sep 12, 2007
    11
    I've the same problem
    I have the same problem, I upgrade my linksys SPA3102 to fimeware 5.7, but the problem still yet, but I can see that if I change the type of the line (Checked external line), in the firts seconds I can make out coming calls, or if reset my router or change outcoming delay, I can make one out coming call.
    can some body anwer about this problem, I have configured like the manual, and I'm using my SPA3102 over my Internet Interface, and I put static IP ()fre ip of my network) , gateway (my gateway), dns (my DNS) ...
    Them I can make incoming calls but this hung up for the linksys gateway make that my x-lite 3.0 disconect the call. I think that it's aVoIP to PSTN configuration error, but I don't know the solution, please can some body explain us the solution??? (I'm in spain)
  3. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Check on the phone interface - admin, advanced, Ext 1 tab - Call Settings section - Blind Attn-Xfer Enable: set to Yes.
    I think that was what fixed my transfer issues.
  4. Joka
    Sep 19, 2007
    SO problem!!!
    Using:eek:ffice fone, LG LDK-100, FXO Dlink DVG3004S, 3CX Enterprise, FXS Dlink DVG2004S, two end office fones.
    if ring from LDK -100 to one office fone, and after transfer on second end fone, see next situation:
    11:34:39.234 StratTransfer::eek:nConnected [CM008008] Call(641): Transfer: wrong leg is connected
    11:34:39.000 StratLink::Transfer [CM104002] Call(641): transfers Ln:1149@DVG 3004S from Ext.201 to sip:202@10.1.1.68
    11:34:38.796 MediaServerReporting::RTPSender [MS004001] Call(642) Ext.202: Can't send RTP stream to 0.0.0.0:41002 destination unreachable
    11:34:34.500 CallLegImpl::eek:nConnected [CM103001] Call(642): Created audio channel for Ext.202 (10.1.1.251:41002) with third party (10.1.1.251:41000)
    11:34:34.500 StratInOut::eek:nConnected [CM104005] Call(642): Setup completed for call from Ext.201 to Ext.202
    11:34:34.500 CallLegImpl::eek:nConnected [CM103001] Call(642): Created audio channel for Ext.201 (10.1.1.251:41000) with third party (10.1.1.251:41002)
    11:34:31.484 CallConf::eek:nProvisional [CM103003] Call(642): Ext.202 is ringing
    11:34:31.359 CallConf::eek:nIncoming [CM103002] Call(642): Incoming call from 201 (Ext.201) to sip:202@10.1.1.68
    11:34:23.187 MediaServerReporting::RTPSender [MS004000] Call(641) Ext.201: (ACTIVE): Can't send RTP stream to 0.0.0.0:41000 destination unreachable
    11:34:17.484 CallLegImpl::eek:nConnected [CM103001] Call(641): Created audio channel for Ext.201 (10.1.1.251:41000) with Media Server (10.1.1.68:7242)
    11:34:17.484 StratInOut::eek:nConnected [CM104005] Call(641): Setup completed for call from Ln:1149@DVG 3004S to Ext.201
    11:34:17.484 CallLegImpl::eek:nConnected [CM103001] Call(641): Created audio channel for Ln:1149@DVG 3004S (10.1.1.253:16386) with Media Server (10.1.1.68:7240)
    11:34:15.921 CallConf::eek:nProvisional [CM103003] Call(641): Ext.201 is ringing
    11:34:15.765 CallConf::eek:nIncoming [CM103002] Call(641): Incoming call from 1149 (Ln:1149@DVG 3004S) to sip:10.1.1.68
  5. gleuto
    Oct 15, 2007
    call drop after 20sec after transfer
    I am tearing my hair out!!! :cry:
    I am using Linksys IP SPA942 phones, but I don't think it is related to the phones because it also hangs on the softphones.
    We receive a call... transfer to another extension... bingo... the call drops after 15-20 secs after the transfer... can't find any help!!!
    Anyone else having this issue?
    here is a dump of the log:
    "Transfer: wrong leg is connected" seems to be the explanation.
    13:49:19.531 MediaServerReporting::DTMFhandler [MS211000] Call(181) Ln:88013443@diva: DTMF (RTP) from 10.37.32.10:30318 arrived. in-band DTMF tone detection is turned off.
    13:49:11.265 StratTransfer::eek:nConnected [CM008008] Call(181): Transfer: wrong leg is connected
    13:49:11.156 StratLink::Transfer [CM104002] Call(181): transfers Ln:88013443@diva from Ext.443 to sip:440@10.37.32.10
    13:49:06.765 CallLegImpl::eek:nConnected [CM103001] Call(182): Created audio channel for Ext.440 (10.37.32.215:16420) with third party (10.37.32.212:16408)
    13:49:06.750 StratInOut::eek:nConnected [CM104005] Call(182): Setup completed for call from Ext.443 to Ext.440
    13:49:06.750 CallLegImpl::eek:nConnected [CM103001] Call(182): Created audio channel for Ext.443 (10.37.32.212:16408) with third party (10.37.32.215:16420)
    13:49:04.765 CallConf::eek:nProvisional [CM103003] Call(182): Ext.440 is ringing
    13:49:04.671 CallConf::eek:nIncoming [CM103002] Call(182): Incoming call from 443 (Ext.443) to sip:440@10.37.32.10
    13:49:02.750 MediaServerReporting::RTPSender [MS004000] Call(181) Ext.443: (ACTIVE): Can't send RTP stream to 0.0.0.0:16406 destination unreachable
    13:48:49.187 CallLegImpl::eek:nConnected [CM103001] Call(181): Created audio channel for Ext.443 (10.37.32.212:16406) with Media Server (10.37.32.10:7342)
    13:48:49.171 StratInOut::eek:nConnected [CM104005] Call(181): Setup completed for call from Ln:88013443@diva to Ext.443
    13:48:49.171 CallLegImpl::eek:nConnected [CM103001] Call(181): Created audio channel for Ln:88013443@diva (10.37.32.10:30318) with Media Server (10.37.32.10:7340)
    13:48:46.515 CallConf::eek:nProvisional [CM103003] Call(181): Ext.443 is ringing
    13:48:46.343 CallConf::eek:nIncoming [CM103002] Call(181): Incoming call from 414453886 (Ln:88013443@diva) to sip:88013443@10.37.32.10
  6. LORD ORION
    Jul 23, 2007
    39
    Did you try
    1) Uncheck "Supports replaces" on the extension, and if that doesn't work then
    2) Uncheck "Supports reinivite" on the extension
  7. gleuto
    Oct 15, 2007
    call drops after transfer
    tried that... but it still drops...
    see error:
    07:54:38.281 StratTransfer::eek:nConnected [CM008008] Call(3): Transfer: wrong leg is connected
    07:54:38.078 StratLink::Transfer [CM104002] Call(3): transfers Ln:88013440@diva from Ext.440 to sip:470@10.37.32.10
    07:54:36.250 CallLegImpl::eek:nConnected [CM103001] Call(4): Created audio channel for Ext.470 (10.37.32.165:39704) with Media Server (10.37.32.10:7010)
    07:54:36.234 StratInOut::eek:nConnected [CM104005] Call(4): Setup completed for call from Ext.440 to Ext.470
    07:54:36.234 CallLegImpl::eek:nConnected [CM103001] Call(4): Created audio channel for Ext.440 (10.37.32.215:16396) with Media Server (10.37.32.10:7008)
    07:54:28.781 CallConf::eek:nProvisional [CM103003] Call(4): Ext.470 is ringing
    07:54:28.500 CallConf::eek:nIncoming [CM103002] Call(4): Incoming call from 440 (Ext.440) to sip:470@10.37.32.10
    07:54:22.218 MediaServerReporting::DTMFhandler [MS211000] Call(3) Ln:88013440@diva: DTMF (RTP) from 10.37.32.10:30002 arrived. in-band DTMF tone detection is turned off.
    07:54:19.531 MediaServerReporting::RTPSender [MS004000] Call(3) Ext.440: (ACTIVE): Can't send RTP stream to 0.0.0.0:16394 destination unreachable
    07:54:16.656 CallLegImpl::eek:nConnected [CM103001] Call(3): Created audio channel for Ext.440 (10.37.32.215:16394) with Media Server (10.37.32.10:7006)
    07:54:16.625 StratInOut::eek:nConnected [CM104005] Call(3): Setup completed for call from Ln:88013440@diva to Ext.440
    07:54:16.625 CallLegImpl::eek:nConnected [CM103001] Call(3): Created audio channel for Ln:88013440@diva (10.37.32.10:30002) with Media Server (10.37.32.10:7004)
    07:54:13.859 CallConf::eek:nProvisional [CM103003] Call(3): Ext.440 is ringing
    07:54:13.687 CallConf::eek:nIncoming [CM103002] Call(3): Incoming call from 414453886 (Ln:88013440@diva) to sip:88013440@10.37.32.10
