Attended Transfer greyed out in CTI Mode
Discussion in '3CX Phone System - General' started by smartdial, Mar 29, 2016.
  1. smartdial
    Apr 17, 2012
    I'm using 3cx Phone for Windows V14 and a Yealink T46G
    When in CTI mode the Attended transfer is greyed out.
    Any ideas?
  2. David10
    May 26, 2015
    16
    Features are normally grayed out when they aren't supported or available.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,380
    84
    Is the T46 a remote STUN extension?
    Attended transfer is available when:
    - The deskphone is either a Local Extension or through a 3CX SBC.
    and
    - The 3CXPhone app is on the same LAN as the deksphone and they can directly communicate with each other.
