Attended Transfer Greyed out
Discussion in 'Windows' started by adamwells, May 5, 2015.
  1. adamwells
    Mar 20, 2015
    25
    User can attended transfer via her phone handset, but not via the 3CX phone software. The button is greyed out. She can dial via 3CXPhone so it's connected.
    Any suggestions?
  2. Thomas 3CX
    3CX Support
    May 6, 2015
    15
    Could you please tell us which phone (brand/model) and which 3CX Phone version you are using ?
    Thank you in advanced,
    Thomas
  3. adamwells
    Mar 20, 2015
    25
    Thanks for the reply.
    Phone is a Yealink T46G
    3CX Ver is 12.0.37098.0
  4. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi Adam,
    Please note that attended transfer in CTI is available in v12.5 of the 3CX Phone System
    Regards
