Attended transfer shows extension number in the call history instead of the caller number
Discussion in '3CX Phone System - General' started by Markus, Nov 24, 2015.
  1. Markus
    Aug 19, 2011
    We have a problem with attended transfers and the call history. If an extension receives an attended transfer, the call history shows up the extension which has transferred the call and not the actual caller. In case of a blind transfer it shows up the caller number in the call history. Is this a setting or can this be fixed that the actual caller is shown in the call history?
    We are using 3CX V14 SP1.
    Thanks,
    Markus
  2. Markus
    Aug 19, 2011
    Does anybody have the same problem?
    Thanks,
    Markus
  3. kusig
    May 18, 2015
    15
    Same problem here with V15SP4 still not fixed and not working for attended and blind transfer.
  4. JasonNadeau
    JasonNadeau Member
    Oct 14, 2015
    262
    46
    I believe this is an endpoint "issue", not a 3cx one. What phones are you using ?
  5. kusig
    May 18, 2015
    15
    We have normal 3CX Windows Clients in use and some Siemens Gigase SL610 DECT connected via a N510 IP gateway.
    There seems to be a difference in behaviour dependent on the device where the transfer is executed. If executed on 3CX Client, the entry is right but not if the transfer is executed on a DECT-IP device. Created a specific Thread for this as this thread seems to be not applicable anymore on this specific problem.
    #5 kusig, Mar 30, 2017
