Attended Transfer Yealink T29G, T46
Discussion in '3CX Phone System - General' started by Milton Schreiber, Nov 20, 2017.
  1. Milton Schreiber
    Dec 31, 2016
    18
    Is anybody successfully doing attended transfers on Yealink T29G's or T46's? I've been trying the methods at:
    https://www.3cx.com/blog/voip-howto/blind-attended-transfer-yealink/
    and
    https://www.3cx.com/blog/voip-howto/blind-attended-transfer-yealink-t48-t46/
    with no success. These methods lose the initial caller or at best result in a blind transfer.
    I wish we could do attended transfer using the BLF fields on a T46, but we've had no luck with that either.
    Any help will be greatly appreciated.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,325
    221
    YiannisH_3CX likes this.
  3. Milton Schreiber
    Dec 31, 2016
    18
