Audible beep tone during call recording
Discussion in 'Ideas' started by RogerS, Dec 14, 2017.
Audible beep tone during call recording 5 5 3votes
5/5, 3 votes
  1. RogerS
    Dec 12, 2017
    14
    11
    An audible beep tone should be heard by all call participants during the call recording, at least at the start and stop of recording, but ideally every each 20 seconds: it should then be possible to configure the wished interval time.
  2. Valentin Studer
    Dec 15, 2017
    8
    We already have been hearing for the requirement of this fuction a lot of times. Small function, but would be a big step forward.
  3. Silly English Kniggit
    Sep 13, 2017
    220
    89
    If this is accepted for change - please make it optional, not default / enforced.
    Eliq91 likes this.
  4. kieferschild
    kieferschild New Member
    Jul 1, 2016
    170
    17
    Ah, that's annoying. Hearing a beep every so often. What's wrong with notifying the customer pre call that their call is recorded?
    Eliq91 likes this.
  5. Alden Lorimor
    Feb 23, 2018
    8
    We would really like to see this feature added. Currently we cannot legally record calls from certain geographical regions without having some sort of notification to the external party. Ideally there would be an option to either prompt at the beginning of the call or introduce a quiet beep every 15-20 seconds during the call. Having this option to do this system wide or by extension is always ideal.
