Audio Code MP-118 and Auto Attendant
Discussion in '3CX Phone System - General' started by mtp3cx, Mar 22, 2008.
  1. mtp3cx
    Mar 22, 2008
    5
    I'm using an Audio Codes MP-118. When you dial into the system I have the auto attendant pick up. However, before the auto attendant plays, you hear a beep. Does anyone know what this is?
  2. mtp3cx
    Mar 22, 2008
    5
    I have a shoretel VoIP system that the T1 hits first, then I have 8 analog lines going into it...
  3. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    I didn't have a "beep" but dial-tone after the MP-118 picked up - for about 20 seconds, before the automated attendant picked up (using the 3CX recommended settings). Eventually I set the "Hotline" wait/delay from the default down to 0 - that took care of it.
  4. Stuck101
    Jul 15, 2008
    30
    Hello, I just setup an AudioCodes MP-114 (Firmware Version 5.20A.031.007) and we are experiencing this same very strange initial beep sound just before our main greeting is played on incoming calls. I have searched config settings & forums for days now to no avail. Can anyone tell me how to remove this annoying beep?
    Although this AudioCodes gateway is way complex to setup, I have everything else (call disconnect, caller-ID, etc) working great with this gateway & the audio quality is superb!
    Thanks in advance!
  5. Anonymous
    Anonymous Guest
    Stuck101,
    Which telecoms provider is this?
  6. Stuck101
    Jul 15, 2008
    30
    Thank you for your reply Keith!
    We have an Embarq PSTN line connected to the AudioCodes gateway.
    This strange beep only started to occur after I started using this Audiocodes gw, prior we were using a Grandstream GWX-4104 and never experienced this beep. I also have a Broadvoice VOIP line in use and have confirmed that this initial "beep" does not occur for incoming calls on this line.
    Also, we are running 3CX Version 6.0.664.0
    Thanks in advance!
  7. Stuck101
    Jul 15, 2008
    30
    Thanks for your reply Matt!
    I just set the line up to ring directly to an extension, and the same exact loud beep sound occurred just before the mailbox greeting was announced. :|
  8. Stuck101
    Jul 15, 2008
    30
    Thanks Matt!
    Just tried this, no beep was heard.
    This has to be (or at least I think it has to be :lol: ) some sort of a signal tone being sent from the AudioCodes MP-114 FXO gateway to 3CX. As I mentioned, this loud beep never occurred with calls coming thru the Grandstream gateway.
  9. Stuck101
    Jul 15, 2008
    30
    Thanks Matt, that may be very helpful!
    Since after several long days/nights of setting up the AudioCodes and finally getting everything else working perfectly, I am afraid to just re-upload a new config file, however, maybe I will locate something in your config different from mine which would appear related directly to this beep problem, or some type of signal being sent causing the problem.
    Thanks again for your help all !
  10. Stuck101
    Jul 15, 2008
    30
    Sent you a PM Matt.
    Thanks again for all your assistance! 8)
  11. Stuck101
    Jul 15, 2008
    30
    Thanks a bunch Matt !
    I will re-upload the config & progress tone files, and test our system to see if the obnoxious beep is gone and report back. 8)
  12. Stuck101
    Jul 15, 2008
    30
    Re: Audio Code MP-114 and Auto Attendant
    Hello Matt,
    Thanks again for all your help!
    Still unable to get rid of the obnoxious initial "BEEP" sound on incoming calls :evil: . I have tried every possible setting & looked thru every config file I can imagine to no avail ! If there is anyone with an idea as to where this beep sound is coming from please let me know. I believe it is coming directly from the Audiocodes gateway.
    On a positive note, the gateway is releasing every call perfectly within two seconds of the party hanging up! Caller ID is also consistently being passed thru.
    I have attached my AudioCodes Config file for your reference, hopefully it helps yourself & others with the inbound call line release issue!
  13. Stuck101
    Jul 15, 2008
    30
    Thanks Matt!
    Actually, as you had mentioned, I was able to locate & upload the USA progress tones.dat file from the Audiocodes CD, made no difference in removing the "BEEEEEEEEEEEEEEP". I am burned out on the flippin beep issue for today..... :lol:
    Anyways, I am anxious to see if my config file helps with the line release on ended calls issue!
  14. ntg
    ntg
    Oct 19, 2008
    I'm considering adding the 3CX PBX to our PBX offering. Up until now, we exclusively use Asterisk based PBX solutions. Oddly enough, I have a similar issue with the AudioCodes MP-118. I have an install whereby 2 companies are sharing one Asterisk PBX w/2 MP-118 FXO gateways, one for each company. Gateway A autodials ext2050, Gateway B autodials ext2051. Inbound calls are set to ring the reception group for 2 rings, if not answer, "all phone" group for 2 rings, if not answer, play automated attendant. Problem is, after a few days of operation, both devices, on one of the POTS lines, answers the call with either a beep, or a continuous dtmf tone. The caller hears the beep or tone, the callee hears silence. The only thing that "fixes" it is a board reset on the MP-118, and then we are fine for another 2 - 4 days. Also, another client started exhibiting the same issue. They also have a MP-118. Per support, (I purchased these from voipsupply.com), I upgraded the firmware to 5.20A.040.004. The problem "appears" to have gone away on all but one of the MP-118s.
    This beep / tone issue seems to coincide with when I started manipulating the disconnect supervision settings, trying to fix a "hang-up detection" issue.
    I have 10 PBX's in production. This issue is only occurring with my MP-118 installs.
    Has anyone cracked this beep / tone issues?
    Brian Franklin
