Audio Codecs
Discussion in 'Windows' started by Parrot, Jul 13, 2009.
  1. Parrot
    Jul 13, 2009
    What codecs does the latest version of the softphone support and what is the latest version release? Thnx
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
