Audio codes MP-114 VoIP Gateway
Discussion in '3CX Phone System - General' started by kp_odata, May 8, 2007.
  1. kp_odata
    May 7, 2007
    6
    Is there pre configured template for Audio Codes MP-114 Gateways?
    Any suggestions/pointers will be of help
    Thanks in advance
  2. brianfpmoab
    Mar 15, 2007
    17
    kp_odata,
    Check out the thread on the MP-108 here
    http://www.3cx.com/forums/viewtopic.php?t=90
    There are ini files for the 114 and the 118 posted there that work. I have 2 114s and 1 118 and have moved the ini files between them without issue. You will need to change the authentication info, IP's and the caller ID but other than that you should be OK.
    Hope this helps.
    Brian
  3. kp_odata
    May 7, 2007
    6
    Re Audio Codes VoIP MP-114 FXO
    Thanks very much indeed Brian.
    It did work!!
    bye for now
    Krishna
