Solved Audio Conference Emails Not Going Out
Discussion in '3CX Phone System - General' started by Brett Coleman, Oct 10, 2017.
  1. Brett Coleman
    Jun 20, 2017
    27
    Where can I look to try and find out why audio conference emails are not being sent?
  2. GiannosC_3CX
    GiannosC_3CX Guest
  3. Brett Coleman
    Jun 20, 2017
    27
    I tried using the Windows 3CX client and also the webportal, both did not send any email announcements. The conference tests all started at the correct times.
  4. Brett Coleman
    Jun 20, 2017
    27
  5. Brett Coleman
    Jun 20, 2017
    27
    John Ranger likes this.
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,301
    530
    Glad the issue was resolved and thank you for sharing your solution
