Audio Cutting Out
Discussion in '3CX Phone System - General' started by TCF, Nov 19, 2015.
  1. TCF
    TCF
    May 6, 2015
    92
    We are having issues with our audio. It will cut out on just about every call randomly for about 1 second. I have tried every combination of codecs, some seem to make the issue better but it never fully resolves. I know it is not a firewall issue, and we have the latest Time Warner docsys 3 cable modem. Does anybody have any suggestions on settings I can adjust to try and fix this?
    Internet Speed:
    Download - 60mbps
    Upload - 6mbps
    No more than 4 active calls at one time
  2. nikosT_3cx
    3CX Support
    Jun 2, 2014
    57
    please open a ticket on our Support portal and provide us a wireshark capture and the Support files of the Phone System in order to analyze them and see from where the issue comes from.
