Audio files compression
Discussion in '3CX Phone System - General' started by itathomeinc, Mar 28, 2011.
  1. itathomeinc
    Mar 20, 2011
    11
    Is there an optimal compression rate for audio files for music on hold and digital receptionist? I have custom audio files for the digital receptionist and coverted mp3 to wav files for music on hold. They sound fine on the computer, but over the phone are distorted. Sorry if any tyos as I'm typing this on my blackberry. Thanks for any help anyone can provide.
  2. willow
    willow Member
    Mar 1, 2011
    471
    8khz, 16bit mono PCM
  3. itathomeinc
    Mar 20, 2011
    11
