audio-in not good, audio-out good
Discussion in '3CX Phone System - General' started by 0zzy, Apr 4, 2017.
  1. 0zzy
    Mar 29, 2017
    11
    Hi, very often, when we receive a call our customers can hear us very well, but we can't hear them so good becouse the voice is intermitted.
    The same problem happen with two different trunk provider.and Internet connection is fine, and also 3cx internal server is not busy.
    What else can i check ?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,381
    278
    Hello @0zzy
    The way to see where the bad audio comes from is by using wireshark to capture the traffic on the PBX server. Then you can decode it by call legs and listen to it. That way you will determine where the bad audio is coming from.
  3. 0zzy
    Mar 29, 2017
    11
    Hi YiannisH_3CX, what kind of information have i to search? filtering for a specific protocol or port or someting particular?
    I have seen there is a dedicated tab for voip calls, i will check there
    #3 0zzy, Apr 4, 2017
  4. leejor
    10,362
    227
    Have you tried eliminating/swapping any hardware on your network, switches and the like? Is this an issue that just started happening? If so, were there any changes made on your network?
  5. 0zzy
    Mar 29, 2017
    11
    no, our customer care is directly attached at the main switch.
    This issue is present from the beginning when 3cx was installed from our it partner, but this does not happen continuosly.
    I think wireshark could be useful to understand (dropped frames or something else) but i don't know what else check.with it
  6. leejor
    10,362
    227
    Have you ever run any sort latency tests on your broadband connection? There are a number of "free" ones available, if you do a search. Can't vouch for any in particular, but if you try a few, and results are consistent in showing a problem, you might want to talk to your provider, or have your network "reviewed".
  7. YiannisH_3CX
    May 10, 2016
    4,381
    278
    There is a tab for voip calls but if you are not familiar with wireshark then it won't be easy to extract the audio and see where the issue originates.
    You will need someone who is familiar to guide you through the procedure or some time in google to familiarise your self with the procedure.
  8. 0zzy
    Mar 29, 2017
    11
    Hi iannisH_3CX, i have taken a log during the comunication issue. There are a lot of error with GVSP protocol (?) as you can see on the attachment below.
  9. 0zzy
    Mar 29, 2017
    11
    Hi leejor, are you talking about a speed test on our hdsl? is the first test i make when the issue happen to exclude bandwith problem. But it is alsway at full speed.
  10. leejor
    10,362
    227
    Speed test is one thing, a latency/jitter test would highlight possible causes of voice issues
  11. 0zzy
    Mar 29, 2017
    11
    Can you suggest me sometihing to try?
  12. 0zzy
    Mar 29, 2017
    11
    I have filtered a conversation, and as you can see there are a lot of malformed packets from 3cx ip to client ip, could it be useful?
    we need to solve this issue, can i open a ticket to the official support?
  13. YiannisH_3CX
    May 10, 2016
    4,381
    278
    To open a support ticket you need to either be a partner or have a support contract or find a partner who will open a ticket for you.
