Audio issue on Sony Xperia Z3 compact
Discussion in 'Android' started by datamerge, Nov 23, 2015.
  1. datamerge
    datamerge New Member
    Nov 19, 2014
    169
    19
    Hi All
    I have a Sony Xperia Z3 Compact and I believe it to be incompatible with 3CX phone 14.
    When I start up the app and call to or from the phone handset via 3CX, the call is successful and I have audio on the handset for about 15 seconds, then it stops. Outbound audio to the far end continues. Subsequent calls have no inbound audio at all until I kill the app and restart it.
    Unfortunately I don't have another Android handset to test just now. However, my Iphone client works fine. I have tried in and out of the office with and without the bridge. I am certain it is not a SIP issue, but the actual audio in the phone.
    Is there any debug mode, or log I can check to see if the phone is bombing out in the app?
    Cheers
    Mark
  2. Chris_3CX
    3CX Support
    Nov 4, 2015
    8
    Hi Mark,
    Did you provision this device with a Welcome Email or manually?
    what is the current version of 3CX Phone App you are running?
    What Version of android are you running?
    If you are running a custom ROM have you tried to reverting back to the official ROM for this device.
    Have you tested or seen any difference if using the device on Wi-Fi or Data 3g/4g ?
    You can also go into "Settings" >> "Audio Options" on the 3CX phone App and make adjustments.
    Do you have Verbose Logging Enabled? this can be found in the "Advanced Settings".
    Please find this Guide useful http://www.3cx.com/blog/docs/debugging-3cxphone-android/
    Kind Regards,
    Chris
  3. datamerge
    Nov 19, 2014
    169
    19
    Hi Chris
    Sorry I never replied to this. I passed the phone on to my wife and upgraded to a new Xperia Z5. Program is awesome on this phone. Crystal clear audio on all calls.
    Regards
    Mark
