Audio Issue
Discussion in '3CX Phone System - General' started by shatty, Jun 12, 2012.
  1. shatty
    Dec 4, 2008
    28
    Aside from the other problems I am having, the most important one is audio issues. When I receive a call, I can not hear the other person. Firewall check passes without an error. I have ports 9000-9050 tcp/udp forwarded as was as 5060 tcp/udp forwarded. Logs said can not communicate with stun servers. All 3 of them. So i was advised to disable stun server and specify public IP. That fixed the incoming calls so far. But when making an outgoing call, I can not hear the other person but they can here me. In the logs it says "busy" or "busy here" Any ideas?
  2. shatty
    Dec 4, 2008
    28
    11:37:04.945|Call.cpp(1470)|Log2||Call::Terminate:[CM503008]: Call(17): Call is terminated<br>
    11:37:08.555|Call.cpp(42)|Log3||??:Currently active calls - 1: [18]<br>
    11:37:13.337|CallCtrl.cpp(348)|Log2||CallCtrl::eek:nIncomingCall:[CM503001]: Call(19): Incoming call from Ext.252 to <sip:17187485975@192.168.1.20><br>
    11:37:13.338|Extension.cpp(1421)|Log3||Extension::printEndpointInfo:[CM505001]: Ext.252: Device info: Device Identified: [Man: Cisco;Mod: SPA Series;Rev: General] Capabilities:[reinvite, replaces, unable-no-sdp, no-recvonly] UserAgent: [Cisco/SPA508G-7.5.1a] PBX contact: [sip:252@192.168.1.20:5060]<br>
    11:37:13.338|CallCtrl.cpp(540)|Log3||CallCtrl::eek:nSelectRouteReq:[CM503010]: Making route(s) to <sip:17187485975@192.168.1.20><br>
    11:37:13.338|CallCtrl.cpp(730)|Log2||CallCtrl::eek:nSelectRouteReq:[CM503004]: Call(19): Route 1: VoIPline:17187485975@(Ln.10000@Nexvortex - US)@[Dev:sip:nP8884Amgj@66.23.129.253:5060]<br>
    11:37:13.388|Target.cpp(446)|Log2||Target::makeOneInvite:[CM503025]: Call(19): Calling VoIPline:17187485975@(Ln.10000@Nexvortex - US)@[Dev:sip:nP8884Amgj@66.23.129.253:5060]<br>
    11:37:25.428|CallLeg.cpp(316)|Log3||CallLeg::eek:nAnswer:[CM503002]: Call(19): Alerting sip:nP8884Amgj@66.23.129.253:5060<br>
    11:37:25.428|Line.cpp(1461)|Log2||Line::printEndpointInfo:[CM505003]: Provider:[Nexvortex - US] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:nP8884Amgj@108.6.54.34:5060]<br>
    11:37:27.472|CallLeg.cpp(327)|Log2||CallLeg::eek:nFailure:[CM503003]: Call(19): Call to sip:17187485975@66.23.129.253:5060 has failed; Cause: 486 Busy Here; from IP:66.23.129.253:5060<br>
    11:37:27.472|Call.cpp(1154)|Log2||Call::RouteFailed:[CM503016]: Call(19): Attempt to reach <sip:17187485975@192.168.1.20> failed. Reason: Busy<br>
    11:37:27.472|Call.cpp(648)|Log2||Call::DoEndCall:[CM503020]: Normal call termination. Reason: Busy<br>
    11:37:38.557|Call.cpp(42)|Log3||??:Currently active calls - 1: [18]<br>
  3. leejor
    11,095
    327
    Are you able to ping the STUN servers? Could it be a DNS server setting? That indicate that there is a problem and that you may just be ignoring it at your peril. The fact that you have no audio may be a result of disabling STUN, or may be related to the same reason that STUN fails.
    s
    Seems to indicate that your provider is sending back the busy message.
  4. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    Related to STUN... check for port 3478 (TCP and UDP) on your firewall...
  5. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    It appears that you are using nexVortex as your carrier. How long has this install been in-place? Is this anew issue or something that just cropped up? You should not need STUN to accommodate nexVortex. did you use the in-built provisioning template or manually provision? Do you have PBX provides audio checked for nexVortex? It should be.
