Audio issues
Discussion in 'Windows' started by ilssupport, May 19, 2015.
  1. ilssupport
    May 19, 2015
    I have am working on replacing my 3cx host computer windows 2008 server. I have built a new server Windows 2012 and installed the 3cx software (same version 12.5). I took a backup of the old computer and restored it to the new computer. I set the IP on the new computer to be the same as the old computer. I disconnected the old computer from the lan and connected the new computer. All phones appear to register no issue. I can make an interoffice call. When calling an outside line or a remote office it rings, and the call connects, but I get no sound. Seems like a routing or firewall issue but everything works with the original config and the IP (port forwards) should all be the same.
    Thanks in advance.
    11,129
    330
    It sounds as if some ports are still not forwarded properly, or are blocked. Have you tried running the 3CX firewall checker on the new system?
  3. IliasL_3CX
    3CX Support
    Jun 2, 2014
    74
    Hi there,
    As leejor stated is the firewall checker coming up green ? Furthermore can you ensure that SIP/ALG is not enabled on your firewall
    Regards
