Audio not playing
SWSDEV
Forum User
This is wieird... Any audio files that I put inside a component are not playing, but if I copy the workflow of the component to my main flow then it works just perfect.
Have you seen that before?
We have tested it here, and it works...
Can you describe what exactly are you doing? Are you using a menu component, a prompt playback component or a user input component? How does your callflow call your custom component?
Getting Started - Admin
deanhbs
Get 3CX - Absolutely Free!
3CX
