- Joined
- Mar 31, 2015
- Messages
- 45
- Reaction score
- 8
Hi. I've had an issue with a Voiceapp that has been driving me crazy as I couldn't work out what the problem was.
I was using the TTS and the system was working fine but then I decided to convert to static WAVs and use the demo looping digit component to play out numbers.
However there was approx 1 second pauses between each digit when I was using the component. I tried recreating it from scratch and hours trying to debug but couldn't find the problem. Eventually I found that I had put "AllowDTMFInput" to false on my version as I don't want digits to interrupt it. However the demo version had it set to true. This turned out to be the cause of the long pauses. I confirmed by turning DTMFInput off in the demo version and it started to pause.
I thought there might be pauses while waiting to get a DTMF press but not if it is turned off?
Attached are the logs for the relevant part when true and false.
