audio problem after upgrade to 3cx Phonesystem 11.
Discussion in '3CX Phone System - General' started by mic.max, Jul 17, 2012.
  1. mic.max
    Nov 24, 2010
    56
    After i've upgrade from 3cx 10 to 3cx 11 phonesystem, when i receive call in most case (50% of call) the audio voice in output is very bad and incomprensible. With 3cx phonesystem 10 no problem.
    My configuration is:
    3cx phonesystem 11.0 on server Windows 2008 R2 Standard (x64) configured with IIS 7.5
    Gateway Grandstream GXW-4104 (fw 1.3.4.13)
    n. 3 Phone SNOM-870 (fw 8.7.3.7)
    Thanks for your reply
  2. mic.max
    Nov 24, 2010
    56
    i think i've solved a problem. I've activated on network IPv6 protocol and the problem seems not to occur. i test for next day...
  3. stash
    stash New Member
    Feb 23, 2012
    213
    Hi Mic,
    What did you activated on IPv6? I Just want to know the solution you came up regarding this issue because i might encounter this if i will upgrade my v10 to v11. Hope to hear your response.
    Thanks,
    STASH
