Audio problem SPA942
Discussion in '3CX Phone System - General' started by rico06, Jan 16, 2008.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I have two problems:
    1 The caller hear me but not me when I receive a call! I khnow its a codec problem because with the 3CX client no problem . do you have a complet set up to do for the SPA942 phone
    2 When I make a call, when I put on hold they hear the message from the IP provider not the one set in the 3CX system. Also a SPA 942 configuration problem
    Can you help me because it a big probleme for us
    thanks
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Log of call (or better 3CXMediaServer.trace.log) will help to investigate the problem
    remove "Supports re-Invite" tick in provider configuration.
    Regards
